99Mystique ATX
I'm looking for a little bit of help picking out injectors and a MAF for the Cougar. For now I will be running the base Vortech kit (~7psi) on the 2.5L that's in the car. I think I want to go with a 39-42# injector but given that it will be a split port intake I think I want to go with a 0 degree spray angle. I also would prefer it to have an ev6 connector so I don't have to get adapters or splice connectors. I'm not sure if I could grab one out of like an 03-04 Cobra but if someone could give some advice as to what car I could grab these out of that would be awesome.
Also not sure about a MAF but was thinking maybe an 80mm lightning maf or maybe one off an 03-04 cobra. Any suggestions?
EDIT: Ok so I did a bit of research and it looks like the 03-04 cobra has oval ports and thus a 'wide' spray angle. Doing some readings on other forums this can cause a poor idle and obviously is not ideal. It also looks like the lightning injectors may be a better option but are an EV1 connector instead of EV6. Any other vehicles I could grab a larger set of injectors in an EV6 and a narrow spray pattern?
