Installed 2001 Sable 3.0 into 2.5l in 1995 Contour GL auto OBD1 (port matched, i.e. UIM, LIM from 2.5).
The knock sensor from 2.5 does not fit on 3.0.
Currently, old sensor is plugged into 2.5 connector and laying on top of engine. Get code 225 (R) Knock sensor not tested (ignore if not pinging) – KS when running KOEF and KOEO tests.
Should I
- ignore, and tape sensor somewhere in engine room with 2.5 connector?
- get 3.0 sensor and steal a connector from JY for 3.0l and wire connector? Where does the knock sensor mount on the 2001?
- mount 2.5 sensor somewhere on 3.0 block (where)? I would hate to drill, tap on the block.
Should I
