I bought a 98.5 SVT from a fellow GEG'r. When I bought it he said the keyless entry remotes worked fine but after we had a long hard freeze the remotes stopped functioning and he figured they just needed to be reprogrammed because the battery died during this cold weather spell also.
I tried reprogramming and get the first honk when I short the plug but no response from either fob. Bill (previous owner) said he had swapped batteries and I did also just to test it but still no luck. Everything else seems to be working just fine as far as I can tell.
Any thoughts out there on this one? Kind of stumped as everything else works and I believe the power locks wouldn't work either if it was a fuse.
Thanks!
Thanks!
