John Howard
I need to jam the starter ring gear in order to prevent engine rotation for crankshaft bolt removal.
Haynes Contour book, p.2A-7 says,"On models with automatic transaxles, remove the starter and wedge a large screwdriver into the flywheel ring gear teeth."
Could some please explain that technique in more detail? What do you wedge it against exactly? I have the access plate loose as someone here suggested and can get a screwdriver into the ring gear teeth but I'm not sure what to jam it against. Could someone who has done it offer the correct technique?
I'm apprehensive as the ring gear doesn't look too strong. But guys here must have done it many times for timing belt replacement. Any advice is greatly appreciated as I don't want to damage anything. This my first water pump and timing belt repair job. Thanks!
