update
i finally had a code, p1131, i took it to a reliable shop and had them pull the code. their computer showed that i had 7 thousand misfires on #2 cylinder and almost 8 thousand on the #4 cylinder, but zero on cylinders 1 and 3. no misfire codes. the plugs have less than 8k miles on them but the plug wires had an unknown number and they were replaced. i pulled all four plugs and they all looked clean however the #4 plug had evidence of carbon tracking (? is that what it's called?) i cleaned the ceramic on all four plugs, rechecked the gap and reinstalled them. i also reset the timing because the belt tensioner for some reason backed off some and there was almost 3/4 inch deflection in the belt between the cam gears. the bucking doesn't seem to be as bad but it's still there sometimes. the TPS is within range and both O2 sensors checked out. the guy at the shop suggested changing plugs, wires and fuel filter. changed wires and filter and inspected plugs. what else could this be? could the plugs really be bad or MAF need cleaning? thanks in advance for any help.
chris
