pajacobsen
- Joined
- Dec 31, 2006
- Messages
- 16
Hello All,
1997 Contour, V6, MTX.
My instrument cluster light went out. All other lights are good, including engine management lights. Fuse (F31) is good (and I did try another fuse), and dimmer switch is not turned off(!) The rest of the cluster is good (speedometer, for instance, works fine).
I assume bulb is done for, and I have found posting from Tony (TONY2005) on how to change bulb (09-06-2006). I also found posting from SnafuFlux (10-23-2006) discussing similar problem.
My questions are:
1) Tony's post links to illustration -->
http://www.contour.org/mods/mods.php?s=howto&displayid=16
but the link does not work. What do I have to do get the illustration?
2) SnafuFlux references a post Tony that discusses how to determine if the bulb (or the dimmer switch, I think) is bad using a "work-around" before going ahead and changing the bulb. However, this link -->
http://www.contour.org/ubbthreads/s...d=allposts&Main=743905&Search=true#Post744474
also does not work. What do I have to get to this location?
In case the links do no longer work (archived, perhaps), can someone tell me how to determine if the dimmer or the bulb is bad (without taking the instrument cluster out?)
Thanks,
pajacobsen
My questions are:
Thanks,
pajacobsen
