bs98contour
- Joined
- Jan 7, 2011
- Messages
- 11
Having problems installing strut assembly back onto knuckle. Its oem spring & strut assembly. Are there any tricks to getting it back into the car?
I use a big long pipe and sit on it and push the knuckle over the ball joint, I and it in so it holds itselfe the I gtake the pipe out and then I give a good wack on the bottom of the knuckle and she slides in. if still not all the way in put a jack under the lca and put pressure on it, and tap the bottom of the knuckle.
