I need to replace inner tie rods. The parts store lists one for 14 inch wheels and one for 15 inch. I have a csvt with factory 16 inch. Will the one listed for 15 inch work?
I'm curious too. Did you get an answer? The service manual talks about a travel stop on the SVT's so the tire won't rub at maximum lock.
The manual makes it sound like the stop is a seperate piece-not part of the inner tie rod.
I also have an SVT and am faced with the choice of the 14" or 15" but no option for the 16" or a separate listing for the SVT. The alignment shop told me that the threads are too badly damaged from rust to use anymore for adjustment. They are pretty bad, but I didn't think they were not useable, said there wasn't enough metal to chase the threads. So are the 15" inner tie rod ends ones the correct ones?
