Dirtylimey
Absolutely no luck getting my oil drain plug off, same goes for my transmission fill plug. Gave both a spray of WD40 and left for an hour, tried to wrench, tapped with a hammer, sprayed, left again rinse, repeat, et al.
Absolutely no movement. Apart from, of course, when my wrench moved on the oil plug. But dont worry, that was just the bolt rounding. Gahhhhhh
The bulbs weren't too bad, except for the left headlight seems to have almost no room for removing and replacing. That was a PITA to replace...
Not sure what I will do now about those plugs...
/rant
