How to reset the ECU/PCM?
depending on the year there are different fuses to pull. it will be listed in your owners manual.
of you can disconnect the battery for a few minutes.
why do you need to reset the pcm? if its because of a CEL you are better off finding out what the code is and fixing the issue ...
On a 96-99, it is fuse F11 ONLY. There is no need to putz with fuse F4 on any Contour to reset the PCM.
On the 2000, it is fuse F6.
Steve
