solo92s10
Going to walk you through making new mounts for the rear subframe. This requires a welder and a little creativity. Ive owned 2 csvt's now not counting the parts car and both of them have had broken mounts.
First thing you need is an swaybar bushing kit that comes with the bracket, such as energy suspension part #9.5122. Then youll need 4nuts and bolts to fit that. Also need to pick up some 1 1/2" square tubeing.
First thing to do is cut 3.5" of square tubing to fit your new mount.
Then put it in the vice leaving 1/2" above the vice. Then use the vice as a guide to sawzall the 1/2" off. Leaving you with a piece that is 1 1/2" by 1".
Then drill your holes for where your going to weld your nut. Make the holes slightly larger than the bolt size.
Continue to next post-
