You can adjust the throttle body, but all you are doing is screwing things up. The IAC and PCM are relying on that setting being in a certain place, move it and IAC control can get screwy.
CLEAN the throttle blade and bore, sometimes that helps, just did it on a Focus, it did get slightly better. Carbon buildup around the aircrack restricts the slight airleak there.
