iBrent
So I've been having this reoccurring problem in my SVT for probably a few years. It got progressively worse but now I think its reached is peak of annoy-ability.
In all gears, but most noticeably 3rd, between 1500 and secondaries the car will buck as it accelerates. This isn't a misfire, I know what a misfire feels like. I've changed plus and wires several times, as well as the coil, neither of which changed the problem (for better or worse).
I took it to a shop, and they had it on a dyno and replicated the problem. They said the engine was physically moving as the car was "bucking". They suggested changing the engine/tranny mounts. I replaced the roll restrictors to poly-filled by pole120 and with the help of turbofox we put them in. At first I was excited because I thought it had fixed the problem. But here it is a month later and its still there and still extremely annoying.
The car idles low and rough as well, not sure if that's related. No codes, neither pending nor stored. Oh, the shop who had it on the dyno said there was a fuel-trim issue but said it would be really expensive for them to track it down because it wasn't dropping any codes.
I've replaced the following parts within the last 10k miles (car currently has 60k)
Fuel pump
Fuel filter
spark plugs
plug wires
ignition coil
TPS
intake cleaning (off car) with new gaskets
MAF removed from car and cleaned with electrical contact cleaner
PCV valve
So, my request is for someone to drive the car and tell me if I'm stupid and there is no problem, just sucky driving on my part, or if there is in fact something wrong. If you check out my thread in General Troubleshooting (My very own hesitation/bucking thread) and look at the last page, you'll see I'm offering a reward to whomever can fix it, or provide knowledge to fix it. I'll be at Carlisle starting Thursday or we can meet up sometime. If not this week, then the weekend after Carlisle would be best. I'm really fed up with this problem and if no one can fix it I'll probably sell the car at the end of the summer (that would make me very sad).
Fuel pump
Fuel filter
spark plugs
plug wires
ignition coil
TPS
PCV valve
