tsSVT
Alright here's the story. (2000 SVT 2.5) I replaced all of my hoses, new waterpump, new thermostat, new temp sensor, and a used radiator to replace mine that had resevoir tube fitting broken off.
I had the radiator flow and pressure tested before installation. It tested fine.
While I was replacing the waterpump the metal disk that sits in the housing fell out. I'm not sure if it supposed to be able to come out or not. I couldn't remember anyone mentioning it as an issue in the past so I put a little rtv on it to keep it in place and reassembled the pump. This may be an issue that I need to address, but I dount that it is related to the overheating.
The car did fine for a day or two, then started overheating a little. I could turn on the A/C to make the other fan kick on and that would take it down to normal temp. Now it has got to the point that it ovevrheats regardless. The first issue I am seeing is that the low speed fan takes a long time to come on. The car is overheating before it comes on.
My biggest concern is that the radiator isn't getting warm at all. If I understand correctly how our fan system works, the resistor on the bottom corner has to get warm before the it will let the fan kick on.
The thermostat is opening allowing coolant to flow, and as far as I can tell the waterpump is creating pressure. That is what leads me to think that there is some kind of blockage in the radiator itself.
I think I am going to pull the radiator tonight and have a radiator repair shop pull the tanks off, and take my original one with me and see if they can either replace the fitting or the end tank itself.
If any body has any ideas please let me know. I am pretty short on options as to the source of the problem.
Thanks in advance for your help.
