I did some searching and didnt find anything, so my fog lights dont work they are the stock ones. Is there a switch or anything to get them to work?? bulb to check im not quite sure as the car was used when i got it. thanks everybody
The foglamp switch is the same as the headlamp switch. If you pull the switch and it doesn't come on, check Fuse 5 and check that the bulbs are not blown. Low beams and fog. High beams = no fog (unless it has been modified).
