Has anyone ever used this for their car?
Chicago,IL
Autozone touch up spray can silver frost(Below)
Is there anything else you should apply after using this kind of method?
Features & Benefits
Dupli-Color® Perfect Match™ Premium Automotive Paint is an easy-to-use, high-quality, fast-drying, acrylic lacquer aerosol paint specially formulated to exactly match the color of the original factory applied coating. Ideal for use on all OEM paint surfaces, Perfect Match is available in a complete line of exact-match colors for current and late model import and domestic vehicles, making this product ideal for both small scale vehicle touch-up and for painting vehicle accessories.
  • Features EZ Touch 360°™ nozzle
  • Premium automotive paint
  • Duplicates original Nissan colors
  • Ensures maximum coverage
Part Number: BNS0565 Weight: 0.79 lbs Type: Spray Can
Category: Perfect Match
Color: Silver
Auto Paint Type: Basecoat Color Group: Silver Binder Type: Acrylic Color / Finish: Silver Combustible: Yes Dry To Handle: 1 Hour Dry To Re-Coat: No recoat window Dry To Tape: 2 Hours Dry To Touch: 30 Minutes Flash Point: N/A Number Of Coats Recommended: 2 Package Contents: 1 Can Paint Application Type: Spray Quantity (Fl Oz): 8 Shelf Life: 24 Months Solvent Type: Toluene Tintable: No UV / Sunlight Resistant: Yes Units Of Measurement: Fluid Ounces Units Of Measurement Quantity: 8 VOC Regulatory Level: Other Viscosity: N/A Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
^ Just need it for door handles and bottom of the doors^
I would think not. But i wouldn't recommend using that garbage if your car is in great condition. If your car is in good shape, order a pint of Silver Frost paint from a Ford dealer and paint it the real way. It may cost more money but it is worth it.
I wouldn't waste money on that stuff, i have used it before, i also have a CSVT SF, i tryed this in my front wheel wells, where the side skirts meet the well, and it turned out terrible, i go to a place called DURA CHEMICAL, thier paint is an almost perfect match, the guy comes out with a little paint scanning tool, and them mixes up spray cans for 20 bucks, they also do whole gallons and what not
I have had good results with dupli color as a touch up however you will want to clear coat it
I've been trying to find a can of Silver Frost Duplicolor for months. I've tried all the stores in my area, none of them can order it. I tried to buy it online but I can't get an aerosol can shipped to me.
I suppose I'll go to the paint shop and have them mix me up a $20 spray can. I need to get my eyelids painted.
I have used this it was okay for small areas. Good for cheap fix. Its really hard to get it right with a spray bomb no matter what kind of paint you have because blending is hard. There is a reason why paint shopspaint the whole panel.
Duplicolor is cheap JUNK
