bhiggs89
This is rather long.
For those of you with H&R springs, or anyone else knowledgeable about suspension setups, I have some questions and/or concerns.
In Summer/Fall 2010 I decided it would be a good idea to replace the stock suspension (~85K miles). After doing some research I really liked the look of the H&R springs, so I purchased a set of those, as well as new BAT struts, mounting plates, etc.
When I got done replacing everything I was very pleased, the rake looked good, it handled amazingly, fairly stiff. However over the next few months the ride began to get "bouncy", it was still firm going over bumps, but the car would "bounce" afterwards.
After doing some more research I discovered that a previous owner had removed the rear perch mounts. So I went ahead and ordered those, installed them. And while they gave it more of the raked look, they didnt have any effect on the "bounciness".
So last summer (2011) I figured it must be something with the struts, so I ordered some new Koni struts. I only had a chance do replace the rears before winter hit. When replcaing the struts, I noticed the Koni's easy to push in and difficult to pull out. After taking the BAT struts off the car they were harder to push in and would immediately push back out by themselves. Once I got the rear Koni's installed (soft setting) I drove it around a few weeks and didnt notice a change in the behavoir, so I switched them to full stiff, and once again no change.
That brings us to now. So to those of you with the H&R springs, do they "bounce" after going over bumps? Or is there something else causing this? Before I switch out the front BAT with Koni's I would like to know if I need to switch to a different spring setup. Also how are struts supposed to behave when off the car? Should I be able to push down easily, or with resistance?
My Dad's car still has the stock suspension, and while not as stiff as my going over bumps, his does not continue to bounce afterwards.
Cliffs:
Do H&R spring's ride differently than others?
Cliffs:
