shavedsvt
ok, this is going to be a short run of 10 gauge bezels. either you can send me your gauge bezel, or i can get them from the local junk yard for $15 each. when you send then take out all the accessories like vents, clocks and defrost buttons. i am not responsible for these, the bezels from the junk yard will not come with them. they will be in primer. everything used in making these is automotive grade. the pvc is epoxied into place, poly-filler is used to level out any uneven areas. primer will only be sprayed 3-4 inches around the worked area. once in primer i will sand and feather it until it is ready for paint. from there for an extra fee i can either try to match best to stock look, or actually base coat clear coat them. if you would like them painted i will only offer the four basic colors the car came in unless you have a paint code ready for custom painted cars. gauge bezels primed and ready for shipment will run $100 even plus shipping. im in the middle of finding a flat rate box for shipping so everyone pays the same and the price does not change based on location. if interested and your name to the list, after 10 are filled there will not be any more made until there are more interest to fill another 10. heres a picture of the finished product.
from this:
to this:
The List
1.)
2.)
3.)
4.)
5.)
6.)
7.)
8.)
9.)
10.)
thank you for your interest
from this:
to this:
The List
1.)
2.)
3.)
4.)
5.)
6.)
7.)
8.)
9.)
10.)
