Fuse #23
NIghthawk1824
st.Louis ,MO
99 ford contour se sport,
My brothers car lately has been blowing fuse #23 once i put the car into drive. when the fuse blows i lose my blinkers and hvac controls. Once i stop the car and put into park i cannot go back into drive until i change it..i assume this may be a safety feature since i lose my blinkers, but anyways this started about 6 months ago and after blowing 15amp fuses every time i went to a 30amp and it held up until today so i will see what yo guys think.
I checked for any funny lookings and didnt see anything and i wasnt totally sure where the ground is, This is in the fuse box under the steering wheel.
Check the back of the Passenger Compartment fuse panel where Fuse 23 meets Fuse 24 in the fuse box left of the steering wheel. It could be rusted out.
In addition, check the wiring under Fuse 3 in the Power Distribution box next to the battery.
Download an Owners' Manual free. www.fleet.ford.com
Ownersmanual
Fusediagram, fusepanel, fusebox
FUSES
ENGINE COMPARTMENT FUSE BOX (Power Distribution Box) next to the battery
Fuse # - Amp - Color - Circuit
1 - 80 - Black - Main power
2 - 60 - Yellow - Engine cooling fan
3 - 60 - Yellow - ABS braking system, Heater blower motor
4 - 20 - Yellow - Daytime running lights
5 - 15 - Light Blue - Fog lamp
6 - Not used
7 - 20 - Yellow - ABS system
8 - Not used
9 - 20 - Light Blue - ECU
10 - 20 - Light Blue - Ignition switch
11 - 3 - Violet - ECU memory
12 - 15 - Light Blue - Horn, Hazard flasher warning system
13 - 20 AMPs- Yellow - Oxygen sensor
14 - 15 - Light Blue - Fuel pump
15 - 10 - Red - Low beam, passenger side
16 - 10 - Red - Low beam, driver's side
17 - 10 - Red - High beam, passenger side
18 - 10 - Red - High beam, driver's side
PASSENGER COMPARTMENT FUSE BOX
19 - Not used
20 - 10 - Black - Wiper motors (circuit breaker)
21 - 40 - Orange - Power windows
22 - 7.5 - Brown - ABS module
23 - 15 - Light Blue - Backup lights
24 - 15 - Light Blue - Brake lights
25 - 20 - Yellow - Door locks
26 - 7.5 - Brown - Main light
27 - 15 - Light Blue - Cigarette lighter
28 - 30 - Light Green - Electric seats
29 - 30 - Light Green - Rear window defroster
30 - 7.5 - Brown - Engine management system
31 - 7.5 - Brown - Instrument panel illumination
32 - 7.5 - Brown - Radio
33 - 7.5 - Brown - Parking lamps - drivers side
34 - 7.5 - Brown - Interior lights, electric side mirrors, clock
35 - 7.5 - Brown - Parking lights - passenger side
36 - 10 - Red - Air bag
37 - 30 - Light Green - Heater blower motor
38 - Not used
RELAYS
ENGINE COMPARTMENT FUSE BOX next to the battery
Relay - Circuit
R1 - Daytime running lights
R2 - Radiator fan, high speed
R3 - Air conditioning
R4 - Air conditioning clutch
R5 - Radiator fan, low speed
R6 - Starter solenoid
R7 - Horn
R8 - Fuel pump
R9 - Headlight, low beam
R10 - Headlight, high beam
R11 - ECU module
D1 - Reverse voltage protection
PASSENGER COMPARTMENT FUSE B0X
Relay - Circuit
R12 - Interior lighting
R13 - Rear window defroster
R14 - Heater blower motor
R15 - Wiper motor
R16 - Ignition
D2 - Reverse voltage protection
Fuse F23 CJB
Fuse F23 CJB
Since the fuse blows when you shift from P to D, it's probably a short circuit in the backup lamp system that is being activated as you go through the REVERSE position.
To isolate:
Ignition off. Set ebrake.
Place the shift lever in NEUTRAL following the shift-interlock override procedure in your owner's manual.
Ensure a good fuse is installed in F23
Turn key to RUN
If fuse did not blow then, move shift lever to reverse.
If it just blew, that would indicate the backup lamp circuit is the fault.
Possible faults in the backup lamp circuit would include a shorted bulb/socket, piched/damaged wire, or in the case of this owner(http://www.contour.org/ceg-vb/showthread.php?t=32926&highlight=f23), a shorted DTR sensor connector due to corrosion. While his vehicle was a 95, the F23 circuit is essentially identical.
Steve
