sfoster
Be Gentle I'm New Here
My daughter's 99 Contour (built March 99) has an intermitant no fuel pump operation problem. I replaced the fuel pump about a year ago. It has the return type fuel system. About 4-6 weeks ago it started having trouble. The fuel pump would not be operating when first turning ignition on. She would look at the pump wiring and wiggle it. Then it would start. Yesterday when I finally was able to catch it acting up. The pump was only getting 7 volts as measured at the pump plug. I first tried moving one wire at a time. No amount of wiggling changed anything. When I powered the pump with my 12V battery pack it worked. Then I pulled and reseated the fuse and relay just to ensuure that they were fully seated. Then I reset the ECU by disconnecting the battery. I forgot to check the fuel pump operation after reseating the fuel and relay. By at any rate then I reconnected the battery it works. Finally my questions, What is the fuel system operation? Does the ECU directly drive the fuel pump or is there a fuel pump driver module like my 2K focus? What would cause the voltage to drop to 7 V? The obvious thoughts are a wire broke and not making complete comtact. What else should I check? Could it be the ECU? If I replace the ECU with one from a Junk, Opps Auto recycler, does that need to be reprogrammed by Ford or is it plug and play? Thanks in advance.
