superrandomguy
i have the ford cd...followed all the instructions.
it's come down to separating the knuckle from the lower ball joint....and it seems to be impossible without using a spring compressor
do i even need to separate the lower ball joint from the knuckle if i compress the spring enough (or torque the LCA down enough) to get some play and pull out the strut? (also my strut seems to be incredibly stuck inside of the wheel hub)
am i doing something wrong/am i crazy? reading through previous posts i've heard many things so i just want clarification if possible
i'm removing a blown koni adjustable/eibach spring if that makes any difference.
