Arachnid
What I was hoping to be a quick and affordable job, keeps getting worse.
Got the caliper bracket bolts loose, discovered left inside pad totally shot, so I went and got new pads...problem now is, the rotor is utterly frozen to the hub and liberal amounts of penetrant and a 12lb sledge arent doing any good
Any ideas? I know heat is one, but all i have access to is a propane torch. Should I just let it soak overnight and go at it again in the morning or?
