Want to Buy Front-Left hub/spindle assembly.
Kresnik
It's possible that my front-left hub assembly (2000 SVT) might be bad as the grinding noise didn't go away after a new bearing was pressed in. In addition to the hub assembly I will also need the caliper bracket, but not the caliper itself. It's possible that mine is warped cause it keeps hitting the rotor, even though the rotor is true.
Who has one in good shape and how much do you want for it shipped to 49930?
Thanks!
Your rotor is hitting the caliper bracket because the wheel bearing is failing. It causes the top of the rotor to tip towards the car and will rub a groove to the caliper brackets. Fix the bearing/hib, and your caliper/bracket will be fine.
CLASSIFIEDS RULES
Last Updated: 7/20/22
