FastFord
Well the cougar I bought has oil leaking out from between the trans and engine, so I am thinking the crank seal inside the bell housing is leaking. Then I noticed that the DMD pulley has a dent in it causing it to wobble and be unbalanced when running which cant be good for the rod bearings crank seals etc. So I am on the search for a new engine.
My options would be to buy just another escape or taurus 3L for about $600-$800.
Or pay about $1k at the most for a 3L that has 900miles with Kinger PNP 2.5L heads, Pauter Rods, Sealed Power Pistons, and Knife-Edged Crank. Problem with this engine is that it has been in an accident which ripped the front valve cover open, heres pics...
I wont need to use the heads or valve covers or anything, just the bottom end. I am going to simply look at the engine tomorrow, but would like others opinions about using the bottom end of this engine.
