Not sure about the gear set itself. However the input shaft length should be different. Also the final drive is different. Not sure how the individual gears differ.
I'm trying to install the Team M Factory Ford Focus MTX-75 4.750 Final Drive but the shaft is different. Will a focus gear set work in a V6 contour box?
i have a zetec trans case that has a duratec gear set in it that Terry did way back in the day. not sure what it different, but im about to tear it apart to pull gears off of it
