ContourLXinProgress
has anybody ever thought about it?
anybody think it's possible??
its far more work to drop the V6 into a Contour that came with the Zetec than you realize. you pretty much have to replace the whole front clip (except for body panels) so you better have a donor car to get everything you would need.I would think your better off swapping in a csvt engine in than an fsvt engine. The csvt engine would be alot easier and also alot cheaper. Not to mention the fact that the torque provided by the v6 compared to the 4cyl. will be alot better for the heavy contour.
I'm doing it or will be once the body work get finished on my car.
I have a complete SVTF engine, wiring harness, PCM, trans and all linkage sitting in storage.
I don't know if I'll be able to use the trans as of yet or if I'll be using the rod shift MTX-75. I've had all of this this longer then I have had my current contour so I might as well use it for something.
Mark
thats the plan. Granted the MT285 trans is up in the air depending on shift linkage as well as CV shafts which may have to be custom made.
Mark
Mark
Mark
No idea as of yet.
