...for the factory front strut mount and strut bearing.
Pretty simple stuff actually: Wanted to properly retain and center a 2.5" I.D. spring using the factory front upper mount and also use the factory turning bearing. The adapter fully captures the turning bearing in the groove which also helps keep road debris out of the bearing, and retains a 2.5" spring on the other side.
<click the thumbnails for a larger pic>
Spring side of adapter.
Strut bearing side of adapter.
Bearing installed in adapter plate.
Adapter and bearing on upper mount.
Completed Koni front coilover.
