I am opening a new thread for this issue now that I have narrowed the problem down to the EGR. Originally I was trying to find out why my engine was stumbling at low throttle.
So here is the issue. When pressing the throttle a tiny bit the engine stumbles and nearly stalls.
The cause is the EGR opening too soon. I have placed a vacuum gauge on it and witnessed the issue. As soon as I press the throttle a tiny bit the EVR Solenoid lets vacuum through to open the EGR. The causes the engine to stumble badly.
This problem has gone on for more than a year now. There are no fault codes being thrown.
I have replaced the O2 sensors, the Mass Airflow Sensor, the Engine Temp Sensor, plugs, wires, etc.
A couple weeks ago I plugged in a brand new EVR Solenoid as I suspected this was bad. It made no difference. The EVR is good.
I see two possibilities. ONE is that something upstream of the EVR Solenoid is triggering it at too low a throttle position or, TWO, this is normal and that the engine management should compensate somehow and isn't.
I have verified the input and output of the TPS and watched it on my computer (I bought an OBD II appliance and computer program to monitor the engine ECU). The TPS seems normal in operation, however the computer does read 17% or degrees at idle. Can't remember which value it said. That seemed high to me, but it operated normally even so.
So can anyone help? Suggestions on what to check?
Steve
Steve
