rexxdoggy
Okay, so it's been on for quite a while. There are a few uses that this light imposes.
1 Well, no crap, your e-brake is lifted, turning the light on
2 If you have low brake fluid and it dips belows the minimum line, the light will flash, or turn on. Depending on how low.
ALSO! There are two different lightings for that light. A full on bright, to a dimmer status light. I have full brake fluid level, and I also check my e-brake everytime I drive to make sure the light turns on brighter everytime I pull it up. SO, with that, what would cause it to stay on? ABS lines messed up? Sensor broken? It is the dimmer light status of the two. It turns brighter when I pull the e-brake.
Thoughts, ideas, opinions?
Thanks.
Thanks.
