morbid
After 2 days of re-learning perl and almost missing a project deadline, I have ported over my bash script to perl. I have not tested this on windows, but it works on linux... and shouldn't have any problems on other platforms. Any feedback would be greatly appreciated! Since I had to learn perl to do this, it is mostly a direct port.. with some additional minor enhancements. I am planning on rewriting it... as I do not like that each export gets read 5 times. Still though... it parses 6 exports on my laptop in 0.145 seconds... where the bash script took ~1.250 secs.
A little background: I know the displayed peak hp/tq is cool and all, but I think average power is better to know. So I wrote a bash script (what I'm best at, so I could do it quickly). I then found that there's potentially a lot of garbage at the beginning and end of the dyno exports. So I made the script find the best "proper" starting and ending rpm. After that, I wanted it to compare multiple runs of mine... and also a local stock CSVT from the same dyno... so I made it check for the lowest and highest common "proper" rpm points.
With the recent "time" dyno from buckeyesvt, I added time trimming to the script. The findings were not surprising. The time specified by WinPEP was unreliable at best. The trimmed times are simply end_rpm_time - start_rpm_time. No correction or anything. Also unsurprising (going back to the initial purpose of the script), the quickest run times also had the highest average hp/tq -- which often conflicted with the raw WinPEP times. I really wanted to run the script against buckeyesvt's and Rickenbomb's dynos, but buckeysvt (for some reason) never even replied to my pm's.
So... here it is for your own personal consumption. I am interested in feedback... bugs and feature requests.
Please run it with "--help" first, as it explains how to properly export the dyno files, as well as certain options you can specify (like increasing the low rpm point to 5000 rpm to replicate your top end shifting).
NOTE: Specified rpm's need to match the exported rpm format: #.##
So 5000rpm would be "5.00".
NOTE(2): The "hp_min/max" and "tq_min/max" are values from the min/max rpms points... not the actual "peak" values. Also... everything to the right of the "||" are directly taken from the export (no adjusting), with the exception of the rpm's for max_hp/tq.. which the script finds.
Also... thanks to chemguru here for optimization suggestions for the original bash script!
Script:
View attachment dyno-eval.pl.zip
Sample exports. Run 001 is from the local stock CSVT; the others are mine.
View attachment sample_exports.zip
Here's an example of the script output:
Here's the code:
Script:
Code:
$ ./dyno-eval.pl
dyno-eval.pl v1.0-20071006
RPM: low=2.470; high=7.050
File avg_hp hp_min/max avg_tq tq_min/max TIME max_hp@rpm max_tq@rpm time temp F baro humid
001J [SAE] 126.89 52.83/100.93 140.33 112.32/ 75.51 15.45 165.50@6.320 153.05@4.350 17.71 86.57 28.91 5%
006 [SAE] 131.42 69.18/165.88 145.33 147.09/123.60 15.32 177.53@6.500 154.47@5.550 20.49 112.03 29.04 5%
007 [SAE] 130.35 67.19/176.40 144.02 142.88/131.43 15.43 177.09@7.040 152.46@5.550 17.73 111.98 29.01 5%
008 [SAE] 133.26 69.72/175.02 147.48 147.93/130.39 15.08 178.95@6.540 155.73@5.460 15.64 112.44 29.01 5%
009 [SAE] 133.54 69.10/175.61 147.75 146.94/130.80 15.03 178.49@6.750 155.88@5.470 17.80 111.67 29.00 5%
Code:
#!/usr/bin/perl
##[ Details ]################################################################
## Script: dyno-eval.pl
## Version: 1.0-20071006
## License: Distributed under the terms of the GNU General Public License v2
## Purpose: Evaluates exported dyno files
## o finds average hp/tq
## o time from actual (non-inflated) rpm entries
## o compares files; find lowest/highest common "proper" rpm
## Usage: ./dyno_eval.pl compares all dyno files in current directory
## -f<filename> only parse specified file
## -l<rpm> raise low rpm to specified number
## -h<rpm> lower high rpm to specified number
## --help display this help
## Exporting a WinPEP file:
## In the graph, ensure horizontal is set to "rpm"
## File -> Export Data
## All options checked in "Information / Headers"
## "Format For Printing" should be unchecked
## Delimiter set to "Comma"
## For best accuracy, manually set "Step Size" to "0.01"
## Ensure the exported filename is "DJDataExport_RunFile_###.txt"
## You can safely add a character after the ### to make
## identically named files unique (ex: ..._001S.txt)
##[ Change History ]#########################################################
## Release xx Details
## 1.0-20071006 SJ Initial release
## Ported from bash script (dyno-eval.sh-1.2-20071002)
## SJ=Scott Jones(m0rbid@--check_zip_for_this--);
#---[ variables ]---#
$script_version = "1.0-20071006";
$script_name = $0;
$script_name =~ s#^.*/##;
#===[ Usage ]===#
sub usage {
print "\nUsage: ./$script_name {OPTION}\n";
print "Evaluates exported Dynojet files.\n";
print " -f<filename>\t\tonly parse specified file.\n";
print " -l<rpm>\t\traise low rpm to specified number.\n";
print " -h<rpm>\t\tlower high rpm to specified number.\n";
print "\n --help\t\tdisplay this help.\n";
print "\nNote (exporting a WinPEP file):\n";
print " In the graph, ensure horizontal is set to 'rpm'\n";
print " File -> Export Data\n";
print " All options checked in 'Information / Headers'\n";
print " 'Format For Printing' should be unchecked\n";
print " Delimiter set to 'Comma'\n";
print " For best accuracy, manually set 'Step Size' to '0.01'\n";
print " Ensure the exported filename is 'DJDataExport_RunFile_###.txt'\n";
print " You can safely add a character after the ### to make\n";
print " identically named files unique (ex: ..._001S.txt)\n";
print "\nReport bugs to: Scott Jones (m0rbid@--check_zip_for_this--).\n\n";
exit 2;
#===[ Read in array data ]===#
sub read_array_data {
print "RPM: low=" . $lowest_rpm . "0; high=" . $highest_rpm . "0\n";
$printf_format = "%-11s%8s%8s%1s%-6s%8s%8s%1s%-6s%7s%8s%1s%-5s%8s%1s%-5s%7s%8s%7s%7s\n";
printf $printf_format, "File", "avg_hp", "hp_min", "/", "max", "avg_tq", "tq_min", "/", "max", "TIME", "max_hp", "@", "rpm", "max_tq", "@", "rpm", "time", "temp F", "baro", "humid";
printf $printf_format, "-----------", "++------", "++------", "-", "------", "++------", "++------", "-", "------", "++-----", "||------", "-", "-----", "++------", "-", "-----", "++-----", "++------", "++-----", "++-----";
$printf_format = "%-11s%8.2f%8.2f%1s%6.2f%8.2f%8.2f%1s%6.2f%7.2f%8.2f%1s%-5s%8.2f%1s%-5s%7.2f%8.2f%7.2f%7s\n";
foreach $dyno_file (@dyno_file_list) {
open(DYNO, $dyno_file);
while (<DYNO>) {
if ($_ =~ m/^MAX/) {
@dyno_max = split(/,/);
last;
close(DYNO);
while (<DYNO>) {
if ($_ =~ m/^,[^s-]/) {
@__line = split(/,/);
if ($__line[3] == $dyno_max[3]) {
$max_hp_rpm = $__line[2];
if ($__line[4] == $dyno_max[4]) {
$max_tq_rpm = $__line[2];
close(DYNO);
$dyno_file_name = substr($dyno_file, 0, -4);
$dyno_file_name =~ s#^.*_##;
$hp_sum = 0;
$tq_sum = 0;
$index = 0;
while (<DYNO>) {
if ($_ =~ m/Humidity/) {
@dyno_env = split();
if ($_ =~ m/^,[^s]/ && $_ !~ m/-INF/) {
if ($__line[2] ge $lowest_rpm) {
$hp_sum += $__line[3];
$tq_sum += $__line[4];
$index++;
if ($__line[2] eq $lowest_rpm) {
$time_start = $__line[1];
$hp_l = $__line[3];
$tq_l = $__line[4];
if ($__line[2] ge $highest_rpm) {
$time_stop = $__line[1];
$hp_h = $__line[3];
$tq_h = $__line[4];
last;
close(DYNO);
$time_elapsed = $time_stop - $time_start;
$hp_avg = $hp_sum / $index;
$tq_avg = $tq_sum / $index;
substr($dyno_env[8], -1) = "";
printf $printf_format, "$dyno_file_name [$dyno_env[8]]", $hp_avg, $hp_l, "/", $hp_h, $tq_avg, $tq_l, "/", $tq_h, $time_elapsed, $dyno_max[3], "@", $max_hp_rpm . "0", $dyno_max[4], "@", $max_tq_rpm . "0", $dyno_max[1], $dyno_env[1], $dyno_env[3], $dyno_env[6] . "%";
#===[ Find lowest common rpm ]===#
sub find_low_rpm {
while (<DYNO>) {
if ($__line[4] > 99.99) {
$low_rpm = $__line[2];
if ($low_rpm >= $lowest_rpm) {
$lowest_rpm = $low_rpm;
last;
close(DYNO);
#===[ Find highest common rpm ]===#
sub find_high_rpm {
$high_rpm = 0;
while (<DYNO>) {
if (defined($highest_rpm)) {
if ($__line[2] > $highest_rpm) {
last;
if ($__last_hp - $__line[3] > 20.00 && $__line[2] > 6.00) {
last;
$__last_hp = $__line[3];
$high_rpm = $__line[2];
close(DYNO);
if ($high_rpm <= $highest_rpm || $high_rpm) {
$highest_rpm = $high_rpm;
#---[ main ]-----------------------------------------------------------------
print "\n$script_name v$script_version\n\n";
while (defined($_ = shift)) {
/^-l/ && do { $lowest_rpm = substr($_, 2);
if ($lowest_rpm eq "") {
print "Lowest RPM value not specified.\n";
exit 1;
} next };
/^-h/ && do { $highest_rpm = substr($_, 2);
if ($highest_rpm eq "") {
print "Highest RPM value not specified.\n";
exit 1;
} next };
/^-f/ && do { $dyno_file_list[0] = substr($_, 2);
if ($dyno_file_list[0] eq "") {
print "Dyno file not specified.\n";
exit 1;
} elsif (! -e $dyno_file_list[0]) {
print "Specified dyno file not found: $dyno_file_list[0]\n";
exit 1;
} next };
/^--help/ && do { usage(); };
if (!defined($dyno_file_list[0])) {
@dyno_file_list = <DJ*>;
find_low_rpm();
find_high_rpm();
read_array_data();
