I have been struggling with this problem for a week and I hope someone can help me.
1998 SVT Duratec V6 MTX - 66k miles
The engine started started missing badly a week ago. It had original spark plugs and wires so I replaced them with Motorcraft wires and plugs. No change at all. CEL is on and flashing -- codes p0301, p0302, p0303. So all cylinders on the firewall side of the engine appear to be misfiring. I replaced the spark plug wires one at a time, so I know they are correct -- I checked and re-checked. I can pull any one of the 6 spark plugs from the coil pack and the idle changes considerably. So it appears the cylinders are firing, just not firing well. The coil pack tested good, but I replaced it anyway and that made no difference, so I put the old coil pack back on. It was a long shot, but I replaced the fuel filter and that made no difference. I have searched for vacuum leaks and found none. I do not hear the vacuum "hiss", but I sprayed carb cleaner anyway at suspected areas and found nothing.
The only thing that seems out of order is a "puff puff" sound at the top of the engine. It sounds like it is coming from below the UIM just behind the throttlebody. I am really out of ideas and am hoping someone on this forum has seen something similar and can give me a clue.
Thanks...Rick
Thanks...Rick
