Would it be safe to use the fuel pump to drain the fuel tank? I plan on hooking line to the outlet of the fuel filter and powering the pump and pumping the fluid into a gas can.
its been discussed before. not sure there would be an issue but i don't think that i would do that. Should be able to draw off the gas with a syphen (sp?)
either way take the standard safety precautions when handling gas.
I drain the tanks on lots of cars using their own fuel pump before I strip them or send them to the salvage yard. A contour though.... Just pull the back seat out, pull out the pump and siphon it out with a big hose. Much faster, less technical.
