I'm just posting some info for the Transaxle forum:
Its hard to believe what the transmission will do in ford cars when only the range sensor (MLPS sensor) goes bad. It will do some pretty strange things
Example: Spring of 09, i was drivin with no probs whatsoever. Cruising at 45mph just chillin and all of the sudden my trans starts to shift thru its gears randomly. I panicked, i pulled into a neighborhood and it kept randomly banging hard in and out of gear.
Heres what i was thinking:
"Oh F***, its done, toast, gone, fried, what am i gonna do?" Well, no flashing O/D light or check engine light, but i did get a code for the Range sensor (668 if i remember right, could be wrong bout that)
I changed the range sensor; it fixed everything INSTANTLY. No problems afterwards.
So if your trans is acting up like that heres some advice for ya
1. FLUID: its not hard, just a pain. (not a pain for those who care for their car tho) check for bright red color, no burnt smell, and correct level
2. Codes: Don't just go about guessing what could be wrong, the PCM can tell you alot from the codes you get
3. You'd be suprised what will happen if the range sensor (which only tells the PCM what selection the shifter is in) goes bad.
Just throwin out some info for you guys. Hope it helps anyone in need
