montrese04
does a dmd aid in hp gains? I was reading some sight that stated HP gains with a dmd. I thought these things just helped reduce vibration:shrug:
If anything, it would do just the opposite, as it's much heavier than the stock crank damper...
i don't totally agree, it is heavier but not by very much at all. i've had one on both my svts and did not notice any difference better or worse. if anything i only noticed that my steering wheel doesn't vibrate close to as much as it used too, and also throughout the rev range, its smoother.
He was just saying that if it were going to do anything, it would cause you to lose horsepower, not that it did. All a DMD does is add to reliable engine life.
i guess why not go with both of them and when i want to be fast it's not that hard to change:shrug: lmfao
might be a moot point ... i just checked the web site and i don't see duratec ... may have moved on !! Shame really; 'cos they make a streetdampr, which is cheaper and may have attracted new business ...G.The fluid damper is heavier and costs twice as much...
Not so... you just have to search correctlymight be a moot point ... i just checked the web site and i don't see duratec ... may have moved on !! Shame really; 'cos they make a streetdampr, which is cheaper and may have attracted new business ...G.
Not so... you just have to search correctly![]()
