CarpePoon
$350 obo Selling the custom system I built for and removed from my Ford Contour SVT before I sold it. Its custom built for a Contour/mystique. The box is within 1 cubic cm of the subs spec and tuned to 46hz which can't be matched with a prefab box. There are also 2 storage chambers on either side of the sub that I simply never finished making the doors for so they are covered with the carpet. I'll also throw in all the 4ga power, ground and rca cables (3 pair), under hood fuse and fused distribution blocks as well.
The box dimensions are L37.5" x H18.5" Top Depth 8.5" bottom depth 15.5" Even if you buy this just for the equipment and use your own box your getting a steal of a deal.
the amps are a digital Alpine MRD-M501 tested at 578w rms x 1 @2ohm
http://www.crutchfield.com/S-wuTnoZTR5qj/p_500MRDM501/Alpine-MRD-M501.html
and a Alpine MRV-F540 tested at 87w rms x 4 @4ohm
http://www.crutchfield.com/S-d6LjsjklYkp/p_500MRVF540/Alpine-MRV-F540.html
both amps have their bench-test sheets from Alpine.
The sub is a 12" Diamond Audio D6 12d4 This is a massive sub (40lbs,) and is wired at 2ohms.
http://www.onlinecarstereo.com/CarAudio/p_15041_Diamond_Audio_D612D4.aspx
http://www.diamondaudio.com/content/view/129/143/
It also has a Stinger 1 farad capacitor with voltage monitor top built into the box.
http://www.thebassbin.com/product.php?id=1705
