TourEnvy
I was wondering what individuals where doing in order to make clearance for wider rims and/or tires on the rear of our cars.
The inner lip is double thickness making it difficult to bend and also if you didnt notice that is where the outer fender is attached to the unibody via spot weld. Hence the double thickness. This also makes grinding the lip down not a smooth move because you would be removing the spot welds in several areas.
Let me know. Rolling fenders is a curse word around here. It's not beyond me if thats the only method that works on these thick lips
Im just afraid that might not be able to do it.
