Savior
A few days ago, my engine began to chug when I would accelerate. It got worse as the day went on and yesterday it stalled out completely and I had to park it along the street. It had gotten progressively worse as the gas gauge went down, and at the time that I had to park it by the side of the street it would idle OK, but would stall if I pressed the accelerator at all. The gas gauge was near empty at this point.
It exhibits a weird behavior: Whenever I rev to 3,000RPM, the tach needle instantly drops to zero RPMs and the engine chugs and nearly stalls, then quickly recovers and settles itself at normal idle. It's like it can't rev past 3000RPM. It rarely stalls completely, and is *sort of* driveable, very slowly.
I thought my PCM might be on the fritz since I had disconnected the battery terminal a few days ago, leaving the PCM to feel out its settings and recalibrate itself, so i used my XCal2 to return the programming to stock, then back to the 91-Octane performance tune, neither one of which had any effect. Then I limped it to a gas station and filled it with premium gas and let it idle for several minutes. The problem went away! Bad gas? With water in it? That would explain why it got worse as the gas tank got closer to empty (doesn't water float in a layer along the top of the gas?).
But now it is doing it again, intermittently. I poured some HEET water remover into the tank, it seems to have helped a little. What else could be wrong though? Do you think it is just bad, watered-down gas? Do I just have to burn it out? Or is it something more severe, like a dying fuel pump or something?
Oh I forgot, I've had a CEL for about 2 weeks now, it is a P1000 code and a P1131 code. I've read about them a good bit though, and the general consensus seems to be that they don't affect performance, and that it's probably my downstream O2 sensor going wonky. This chugging/stalling/RPM limit just started a day or two ago. Are these things connected?
[EDIT] - The P1131 code specifies that it is trying to compensate for and "over-lean mixture" in the air-fuel ratio, or something like that... If my O2 sensor were dying on me, could the car's attempts to compensate for the O2 sensor's false readings result in this problem? Is this something completely different, or should I replace my O2 sensor?
[EDIT 2] - OK, now it won't start at all.. It just chugs and dies. Crap. Help!
