My alternator is dead, and putting the car into the garage this morning.
Manual says to drop the Y-pipe. Fact or fiction?
If I have a pull the tie road and drop the Y-pipe, this is going to become a very long day. :blackeye:
Edit:
Just adding FYI details, I've noticed a few post where there's no reference to what year/make/engine are referenced. So reading back on old posts becomes less useful without the details!
Car: 1998 Non-SVT Duratec, automatic trans
Steps: Disconnect battery, Raise and secure on jack stands,, remove front passenger side wheel., remove splash shield from inner fender, remove drive belt (might want to do this before lifting vehicle), disconnect outer tie rod from steering knuckle, Unbolt Y-pipe from exhaust manifolds (step in question) , disconnect alternator, remove rear support bracket bolt from the cylinder block, remove upper and lower mounting bolts, remove alternator, install new alternator in reverse order.
Edit:
