Nick Buol
Very strange. I changed the spark plugs on my 1999 Contour SE 2.5L V6. Everything went fine as far as I can tell. The engine runs fine and everything seems fine there, but at lower speeds (from 0 - about 35 MPH), when I step on the gas, the brake light comes on.
I can be at a dead stop, or rolling at 15 MPH, but if I excelerate hard, the brake light comes on and then flickers off as I get up to about 35 MPH. It doesn't matter where the RPMs are at, from 2000 - 6000.
If I press on the brake pedal both during when the brake light is on, or if it is off, the brakes seem to function normally and don't impact the brake light status (if it is on, it stays on, if it is off, it stays off)
The only thing that I can see if the acceleration/speed/RPM combination.
Again, the vehicle ACTS fine, but the brake light comes on. This started right after changing the spark plugs.
Any ideas of what would cause this?
Thanks!
Thanks!
