Redstar
I took my car to a quicky lube and they put in a crappy filter. Can I change the filter without making a huge mess or loosin a lot of oil?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
you better be pretty quick when you swap it, because the oils gonna pour out.
Yea...that's kinda funny.Uhm... what are you talking about?
what oil?
The only oil that can "pour" out is the oil out of the filter you are removing. the REST of the oil is in the oil pan, which is lower (physically) than the filter. I don't see oil jumping up and climbing any hills or fighting gravity just to run out the filter and cause you to have a bad day.
You can be as fast or as slow as you like.. you're gonna lose the same amount of oil; roughly one quart which was pooled inside the filter itself.
