As contour.org is really the best place for CD4E tranny questions, and since the forum rules won't allow me to put this question where it needs to be, I will try to keep this short and sweet. Hopefully someone can help.
I have a 2003 Ford Escape 4wd 110,000mi, CD4E transmission is in pretty much perfect working order except I started getting this acceleration vibration about 1 year ago. I replaced the drivers side CV axle with a reman. unit and it seemed to fix it for a time.
Within 2 months the vibration was back. I bought another CV axle and replaced the previous one. Couple weeks and there is the acceleration vibration again. I finally get under the car, get my wife to shift it from forward to reverse and find there is a huge amount of play (like 1mm) at the inner part of the CV spline where it goes into the transmission. It appears to be at the differential. After some trouble shooting I take it to a shop, they want $3200 to fix it. Ouch.
Fast forward to today. I have the CD4E sitting on the floor of my garage. I have checked the differential, it is within spec. There is a needle bearing assembly (part #7G355) at the Driven sprocket that has some play and will be replaced. Just tonight I noticed something alarming, the Driven Sproket (part # 7G132) inner bearing is shreaded. This is the pressed in bearing that the CV axle rides on. I took a caliper reading of it, the bearing ID is 1.293", the CV axle race is 1.149". That is quite a bit of play. See attached.
My question, is there a way to replace only the race? It is not a separate Ford part number. The Driven Sprocket is $350 new. Junk yard, who knows. That is a lot of money to replaced just the bearing. I don't understand how it got so far off. The tranny shop wasn't sure either. I wonder if the fuild port to the bearing is clogged or something else not getting fluid in there.
Also, anyone know what the ID measurement of the Driven Sprocket bearing is originally?
Thank ahead of time.
