TorkMonster
- Joined
- Apr 20, 2008
- Messages
- 15
On a 1995 2.5l Auto (LX)
I can't seem to get rid of this code.
I replaced both the DPFE sensor and the EGR valve as well as the EGR selenoid.
Ran the car about a week and pulled the EGR again. The EGR tube side was rusty - no soot. exhaust had not been running through the EGR valve! I cleaned out the EGR tube with pipe cleaners and compressed air. I found no blockage, but the tube is clean! The DPFE hoses are properly connected from the EGR valve.
I connected my multimeter to the EGR selenoid lead ant took a test drive. My meter read 13.2 volts for the entire drive. So the vacuum selenoid never opens for the EGR to open up. The selenoid voltage should vary depending on the load of the engine as long as the car is moving.
The wiring looks good - no cracks or missing insulation anywhere.
The question is why?
If the DPFE fails it's test, would'nt the EGR selenoid continue to operate? Anyone had the same experience?
