hourang
So im trying to fix my motor shaking problem. car info in sig. looks like i need the passenger side motor mount. was able to find that on rockauto no problem for like $48. now i checked the front mount by the radiator and it looks good but i have a replacement for that i might swap out anyway. the trans mount by the air cleaner looks good. the rear trans mount next to the flex pipe (which i need to replace), i cannot find a replacement for this. i took a pic of it:
this is a M/T car. the rubber was pretty flimsy and i could lift the trans by hand a little with it attached so im pretty sure its bad. not sure if this is my main problem, im thinking the majority of the issue could be the motor mount by the coolant tank. is this a dealer only item? or even a junk yard only item? is there any way to fill the empty space with like polyurathane or something? here is the only thing i can find on rockauto that is even close to it but im pretty sure this is the trans mount by the air intake:
im not sure if i even want to waste my time with it. i mean it may not hold it in the best, but im thinking that the passenger motor mount is worse and that might fix the problem. its shaking front to back when i first engage the clutch and i can rock the motor by hand back to front. i just wasnt sure if the motor mount on top really affects front to back movement, i dont want to spend $50 and still have it be this mount that i cannot find anywhere. sorry for the long post. please help.
