I'm at my wit's end. 2000 SVT. Got a P0401 EGR flow code. I've reset the computer twice to make sure it's recent.
I've done the following:
Treated fuel with Berrymans
Replaced EGR Valve
Replaced EGR Solenoid
Replaced DPFE Sensor (new style plastic)
Cleaned the EGR port with TB cleaner, and snaked it.
Cleaned the EGR tube with TB cleaner, and snaked it.
Cleaned the TB with TB cleaner.
Cleaned all electrical connectors.
Still, I get the P0401 code. Engine seems to be running perfectly otherwise.
So what's left for me to do? Is it possible the new DPGE sensor is also bad? I double checked that I hooked the 2 rubber tubes up to it in the correct order, should I triple check this? Can those rubber tubes get carbon build up?
How can I check the voltage across the sensor with the engine running?
What else can I check?
Unfortunately if i cant get this car to pass emissions, its off to Kars for Kids.
EDIT: OK after some reading it seems people go one step further and remove the TB itself, and clean the intake passages from that side. I will try that. I will also try the suck test on the EGR. If that passes (killing the motor), does that narrow it back down to the DPFE?
Replaced EGR Valve
