not sure if this is the wrong place for this or not but...
so I am working on removing the heads to replace the head gaskets and some other things. Yesterday morning I removed the timing components. I rotated the engine to get the crankshaft key to the 11 o'clock position and the cams weren't lined up, so I rotated one more revolution. The RFF marks on the RH cams were now lined up but the RFF marks on the LH head were not. So I kept rotating the engine to see if it would line up. Got tired of fighting the compression so I removed the spark plugs to allow the air to escape making it easier to rotate the engine (I didn't get a picture of them yet but the spark plugs look different from head to head). After several rotations I decided that the cams were either installed wrong to start with or when someone did some work on it they re-installed it wrong but the original owner never said anything about work like that ever being done.
Here are some pictures to show what it is I am referring to.
RH
LH
So I went ahead and removed the timing chains, guides, tensioners, cam caps, cams, etc. and figure on installation I will make sure to install the cams in time.
Anyone else ever see this?
What would be some results of the timing being off? I only drove this car for 300 miles after buying it and it felt fine to me but maybe there was something happening that I wasn't aware of.
RH
LH
