hallfleming
C1148 Wheel Speed Sensor RF Coherency Fault
The ABS light was lit when I bought the car. Someone had installed non ABS cv's so I replaced both of them. I still got a error on the front right abs sensor so I swapped the sensor on the hub right to left. Still saw the error. For giggles, I grabbed a spare sensor at a junkyard and its the same. The other day I noticed a dent in one of the pickups on the CV's tone ring. So, I replaced the CV again. Still got the light.
If I look at a realtime datastream with a scanner, I see that all wheel sensors will register the same wheel speed except for the front right one. It either reads 0 or partial speed and sometimes jumps to the correct speed. I've cleaned the connectors where the sensor plugs in the harness. Also, this is my new main harness. It did the same with the old harness.
Any ideas?
Any ideas?
