FrancisPennysac
So sadly, I finally went to change the plugs and wires today on my 98 Zetec ATX mystique and sure enough I got to the last spark plug, the one on the far right from standing in front of the car looking at it, closest to the coil pack. And I thought everything went well, I started it and heard a HORRIBLE knocking sound
I thought I killed it right then and there!!!
I could just cry, I've thrown nothing but hard earned money at this car to try and make it nice and reliable and the simplest things always are the ones that f up. ;(
So I shut it off an checked the last plug I pulled and sure enough about 1/4 of it was broken off the porcelain, and had went inside the cylinder when I removed it. I hadn't noticed this as it was dark and I was cold and everything was going smoothly until this
But a piece of it is inside my cylinder head, so I have read a couple things..
Should I attempt compressed air to blow the piece out of the engine?? What about flooding the cylinder in something that the porcelain is buoyant in,as to push it out the plug hole??
Is my motor F'd??
What is my BEST course of action at this point WITHOUT removing the head. Cause if I do I might as well have it shaved, ported, and head-gasket replaced.
My car is literally 64 miles away from clicking over 150,00 miles exactly...
I am just outside Allentown PA, if anyone can lend a hand!! I obviously can't drive it anywhere.
ANY HELP is greatly appreciated.
Is my motor F'd??
