sorry for the late reply. Not sure if you fixed the axel yet. The passenger side axle has a jack shaft that is bolted to the engine at the shafts bearing, the CV cup is outside the bearing. It is just two 13mm (I think) nuts to remove the shaft then it should just slide out.
