Smalls
Addicted CEG'er
one of my SS brake lines that came with the brakes is garbage. i have no time to wait for another set of lines to come in the mail. will the fittings from the oem lines work with the PBR calipers?
Also, the '94+ Cobras and earlier Vettes use the same PBR caliper as Baer so a dealer may have a caliper fitting that you could use to make a new hose.
I'd still call Baer first.
-J
-Pre '94 cobra banjo bolt thread is M10x1.25 and are incorrect for the baer calipers.
-'94-'04 cobra banjo bolts could possible require more than 2 copper washers to prevent the bolt from going into the pot too far causing it to hit the piston.
[/QUOTE]-Goodridge OEM braided lines are M10x1.0 into the caliper
[/quote]'94 Was the first year of production for the 2-piston PBR's in the Cobra. (not speaking on the 93 Cobra R because I don't remember for sure)
So are you saying don't use/order the Baer stainless lines for the Baer caliper kit because it is unecessary? I think that is what you mean.
If my Baer braided lines with the banjo bolt were bad, I would just go to a OEM stainless braided line, because like stated before, they are the same thread.
I also think the banjo bolt system is more likely to leak because you now have 4 parts (two washers, bolt, and brake line) to make one connection VS just one part (OEM brake line). Just my thought.... I was just getting new banjo bolts because I already have the Baer stainless lines :shrug:
That is what I thought you were saying.... If the offset of the cobra rotors matches up with the wilwood calipers, I will be using the willys for sure anyway :drool:
