CKtour98
So im trying to bleed my powersteering, but it doesnt seem to be working. The car is on the ground, reservoir has been topped with fluid and turning lock to lock over 10 times with the cap off hasnt done anything. The steering shudders when i move the wheels, and makes loud noises so theres gotta be tonns of air in it.
What else can I do to help remove it all? Should I loosen the nut on the hard line (highpressure) and let it "bleed" there for a bit and then try the lock to lock method again? Also, would getting the wheels off the ground maybe help as it wont be as much strain on the pump?
